Пожалуйста, помогите мне в deskproto 5
в оси вращения (rotation axis) загружаю stl format и даёт ошибка:
it is impsible to rotate the part 360 degres round the x-axis.
The problem might be that the x-axis is located outside your part:
to solve this check the option Center Geometry on Tab page Transform.
Other options to solve the problem include:
-scale down the size of the object at the Transform tab
-Change the difinition of your machine in DeskProto (Centre level of the rotation axis)
